Multi-featured system monitor
A multi-featured, low-resource system monitor that lets you easily track and manage CPU, RAM, disk, network, and GPU usage
- Optimized for low CPU usage
- Supports ARM architecture
- Free and open source
Notes for Limitations:
Notes for Flatpak Support:
I Gatshëm Për Arkitektura:x86_64aarch64
