A multi-featured, low-resource system monitor that lets you easily track and manage CPU, RAM,
disk, network, and GPU usage
- Optimized for low CPU usage
- Supports ARM architecture
- Free and open source
Notes for Limitations:
Notes for Flatpak Support:
- Flatpak version of the application uses some permissions (like not sandboxed) to access performance/system
information of the host OS.
- Flatpak package of the application may be installed for system-wide instead of user-specific
for avoiding source code modifications.
Ezt a közösség által biztosított csomagot nem a(z) Hakan Dündar ellenőrizte, nem áll kapcsolatban vele, és nem is támogatja.
