System Monitoring Center
by Hakan Dündar
Multi-featured system monitor
*** Announcement (31.10.2023): End of support for System Monitoring Center ***
- Optimized for low CPU usage
- Supports ARM architecture
- Hardware accelerated GUI
- Free and open source
Notes for Limitations:
Notes for Flatpak Support:
Changes in version 2.26.0
7 months ago
(Built 7 months ago)
Installed Size~13.14 MiB
Download Size3.67 MiB
Installs145,256
